-   -   vac. pump (https://www.racingjunk.com/forums/showthread.php?t=28347)
greenone60 06-27-2010 12:43 PM
vac. pump
is anyone running a ele. smog pump off of a sbc lt1 motor for a vacuum pump.and does it pull enough vacuum and will it increase hp.iam putting one on my 388.any advice
johnracer 06-27-2010 01:19 PM
Seems like there was a thread on here about that a while back. As I recall the guy just wanted to remove condensation from his alky motor and it worked fine for that, but didn't pull enough vacuum for anything else. Personally, I would'nt spend the money on a vacuum pump for an engine that small, especially if you're searching for a power/et gain. Much more cost affective power gains to be had elsewhere.
Even on the big inch engines, the power increase doesn't amount to much if any et gain, but that's usually not the point...
Johnny
