video of car bouncing for the first 100 ft
http://www.youtube.com/watch?v=IyLRzEutk6g what causes this are my shocks set to loose? its a tube chassis ladder bar car with double adjustables afco in rear. the front end has single adjustables with frontend limiters set with about 1/2" of travel. any input guys? thanks mike
Looks like its set to soft, it spins at the hit, unloads the chassis and spins again 10 ft out.
too loose? kind of what was thinking. do you recomend tighting the rebound or the compression? what about the frontend? thanks mike
could be both, where is the compression set now? however stiffer rebound would help, what setting on front shocks.
compresion= #3 on the knob
rebound= 4 spins on the shaft front coil overs???? the limiters have 1/2'' of travel car weighs 2580 with driver. car is a small block car with a glide. 4.86 gear. leaving @ 4400 and shifting at 7000 |
don,t know how many clicks your shock have, but i would go half on compression, and two over half on rebound, and watch the 60, either taking more hit out, or put more in. maybe me but i like a little more frontend travel than that, i am better able to control for the lack of a better word, snap rotation, in other words the frontend comes up too fast, and the tires brake traction. i would try the shock adjustments first, then look at the frontend thing. good luck been there :)
thanks bird!! i will try it this weekend and keep you posted. mike
| All times are GMT -8. The time now is 02:50 AM. |
