WONDERING CAR
WILL WORN OUT SLICKS MAKE MY CAR WONDER LEFT AND RIGHT GOING DOWN THE TRACK?OR DO I NEED TO ADJUST MY BUMP STEER.
I don't think worn out slicks would do that. Slick pressure too low, insufficient toe-in or insufficient positive caster, worn out front end parts or steering gear, worn out rod ends on rear suspension, low front tire pressure, all can cause a wander going down track....if it darts around going over bumps, then maybe bump steer.
Johnny |
I'm COSTANTLY 'wondering' how I get to 'wandering' :shock: :shock: :shock: :shock:
if its a sudden motion, i would be inclinded to think bumpsteer.
Yes no doubt worn out slicks will do this. When a sidewall on a tire goes away this is exactly one of the affect of that. Sidewalls go well before wear holes.
forgot to mention car has moly upper/lower control arms with single adjust coilover shocks.travel limiters are set at 2" of travel.
| All times are GMT -8. The time now is 01:49 AM. |
