-   -   66 nova no power (https://www.racingjunk.com/forums/showthread.php?t=28301)
spool99 06-19-2010 09:08 PM
66 nova no power
I have no headlights, ignition, ect.. Battery and starter are good. Is there a wire in the harness that powers the entire car
DirkaDirka 06-19-2010 10:17 PM
Have you checked your fuses?? To me it sound slike your main fuse might have blown.
Also what it is sounding like is that you have no power at all??
If so also check to make sure the cables are attached to the battery as well as the car. You might have the ground cable disconnected somewhere.
suicidebomb 06-20-2010 05:06 AM
Probably a fusible link
TS1955 06-20-2010 01:49 PM
X2 on a bad ground. I think that is the most over-looked thing when it comes to electrical issues.
TS1955
MEMRACING62 06-20-2010 02:09 PM
check wiring down on the starter?
johnracer 06-20-2010 05:02 PM
If it's the stock wiring, I believe that the ign switch, headlamps etc get power from a fuse link coming off the voltage regulator. If not there, at the battery connection on the starter......
Johnny
suicidebomb 06-21-2010 04:52 AM
I had a '71 blazer that burned up a fusible link, and it killed all electrical power. that's the reason I said that. When I finally found the problem, the fusible link didn't look burned up, but it was. It went from the main harness to, a junctiom block on the fenderwell. But, like others have said above, there could be other causes too.
oldandtired 06-21-2010 11:07 AM
Also note that your front wiring harness plugs into the fuse block harness, going thru the firewall. Maybe some gremlins there?
Dave
