-   -   NHRA RULES reguarding batteries and Optima batteries or dry (https://www.racingjunk.com/forums/showthread.php?t=28258)
bixblk 06-13-2010 09:41 PM
I was told that if you use a Optima battery that you do not need to have a battery box. if the battery is located in the trunk. Street cat runs in the 10's What do you guy think ???? Is that true
TheYellaBrick 06-14-2010 06:08 AM
Most sanctioning racing bodies are allowing 'gel' cell batteries to be used without encasing them. Just make sure you have a very durable mounting system. NHRA does require them out of the 'passenger' area.
bixblk 06-14-2010 06:44 PM
reply
Thanks
that will a little work for a friend of mine
Jeff
