need help on pete jackson gear drive
i have a PJ gear drive and no instructions for a customers motor. it has two dots on the big idler gear and a dot on the crank gear and one on the cam gear so there is a total of 4 dots on this gear and when i degree cam in i end up with 132 centerline, so i cold use help if you can thanks
Dont worry about the dots, degree the cam where it needs to be.
| All times are GMT -8. The time now is 09:15 AM. |
