-   -   g body t-top car help in set up for mid 12's (https://www.racingjunk.com/forums/showthread.php?t=28224)
russ67chevelle 06-08-2010 09:09 PM
my goal is to set up 87 monte ss with t-tops to be a street strip car and itll run mid 12's quarter times.
doing a body off cleaning so wondering what body mounts would be best(poly or rubber)...my buddy said poly i was wondering if rubber would be best as so then the bushings will be more cushon so the torque can be absorbed better than polygraphite bushings....also gonna be boxing frame rails and what u guys think of adding an anti roll bar to prevent body twist???
im deathly scared with a t-top car the body may twist and i dont want to cage it. oh by the way thinking of ordering pst poly front end rebuild kit too.anything im missing please enlighten me im all ears! thanks
JEFF69Z28 06-09-2010 02:26 AM
YOU CAN DO THAT WITH THE RIGHT MOTOR WITH NO PROBLEM.
JEFF69Z28 06-12-2010 03:35 AM
My t-top monte run's 10.20's.never had a problem with the tops.
itsabird 06-12-2010 09:14 AM
I would use poly for body mount also, just for added stiffness.
