-   -   parachute (https://www.racingjunk.com/forums/showthread.php?t=28215)
rich970 06-07-2010 05:35 PM
parachute
i was wondering about the different styles of parachutes. stroud and cross form. i read a little but i would like to from someone using them . Thanks Rich
johnracer 06-08-2010 12:56 PM
I've used Chute Metal & Simpson. Both crossform and almost identical. Only diff is the shroud lines and you can still get Simpson....
rich970 06-11-2010 02:43 AM
Thanks did they hit hard when opening ?
johnracer 06-11-2010 04:51 AM
Not really. It depends on the weight and speed. My dragster only weighed 1500lbs and ran around 150. It hit harder than my Vette with the same size & style chute at 2222lbs and 158mph....neither felt particularly hard to me.
Johnny
MudWild680 06-12-2010 07:26 PM
Ive got a Simspon on the back of a 3000lb Chevelle.
I dont feel it at all back there when i open it up. :cry:
hammertime 06-13-2010 06:51 AM
Stroud is by far the easiest to repack ... 180mph dont even know its back there, I've thrown it once just to be sure it goes out.
chevyfireball 06-22-2010 05:52 AM
I use two Stroud chutes. They are designed to open softer than cross form chutes. They have a spring launcher and are real easy to pack. There is a good article on Dragstuff.com written by Bob Stroud about the differences in the two designs.
http://www.dragstuff.com/techarticles/parachutes.html
