-   -   What is the best way to cut lexan? (https://www.racingjunk.com/forums/showthread.php?t=28147)
bowtie4542001 05-27-2010 02:56 AM
Hey guys, just wanted to know which way is the best to cut lexan. I need to cut out a little section on my Opel and I don't want to run the risk of cracking it. Just about got her put back together and I can almost smell the racing gas. Thanks in advance for the help.
Chris
Tod74 05-27-2010 04:01 AM
I think they sell a cutter made for that....seen them at LOWES I Think...
johnracer 05-27-2010 05:06 AM
Sharp tin snips or a jigsaw work well. If you go the jigsaw route, you'll need to put a heavy layer of masking tape anywhere the saw will touch the surface to prevent marring it......
Johnny
kwkracing 05-27-2010 05:10 AM
jig saw and they make blades for this application.
bowtie4542001 05-27-2010 05:17 AM
Thanks guys for the quick response, I will go to lowes and get some blades.
hammertime 05-27-2010 05:33 AM
x2 ...
brings me back to my days of working at a hardware store ... :shock:
burnskustomz 05-27-2010 07:09 AM
hey guys one thing i've been wanting to know is I have an 85 camaro and how would I make a sheet of lexan fit on the hatch. how would i bend it to make it form the contour of the hatch?
bowtie4542001 05-27-2010 08:13 AM
x2 ...
I will look for the cutter as well. Might provide a cleaner cut. Thanks
Chris
spib 05-27-2010 10:14 AM
as long as you keep the protective film on the lexan, and buy some fine teeth blades for a jig saw it cuts very clean and easy so easy, I can do it, after you lay out template on lexan go to corner and make a few practice cuts, try it with tape on it also, it is very easy
TheYellaBrick 05-27-2010 11:18 AM
Keep your blade speed low, as a higher speed will melt the polycarbonate and clog the blade.
