installing oil accumalator
i have a 90 GT and bought a Moroso oil accumalator,i have never used or installed one,where would u mount it? Also,do you have to drill and tap to plum it on stock oil filters housing or where else could i plum the inlet too?
Moroso has an adapter that goes between the filter and the block. I would use the electric solenoid So it prelubes every time you turn on the ignition. I mounted mine to the firewall just below the master cylinder.
| All times are GMT -8. The time now is 04:08 PM. |
