-   -   Won't start after car warms up (https://www.racingjunk.com/forums/showthread.php?t=27960)
jjam 05-03-2010 04:23 AM
My friend just got a 68 Camaro with a 355 SB, TH-350. But after the car been running for awhile it won't start, I had one like this when I was a kid and it was the Starter was heating up from the header. Is this still the case or possible other problems? And good way to fix this? (Like I said after the car is warm, it act's like no juice to the starter, but after the engine cools 30mins or so it will start fine)
bigmack 05-03-2010 05:48 AM
if it's not your stater make sure you have good grounds you really need good grounds so engine to frame, frame to body the more the better good luck. bigmack.
bokal 09-06-2010 02:32 PM
wont start
wont start wont turn over turns over but wont start have to know this to help
signsbyesa 09-06-2010 03:36 PM
yup bokal x2, if the motor is turning that means the starter is working,
if the starter won't turn the motor just hummmms, starter is getting
hot, which is it? can use a heat shield or wrap the headers around
the starter, good luck bud
