help with what hp im making
I've been running a 406 sbc that is 9.25/1 cr with 10lbs of boost and brodix track 1's with a comp roller cam .575 .575. Now I goin to a 427sbc that is 10/1 cr and still 10lbs of boost same heads but I'm goin to a .644 .604 roller 7-4 swap blower cam! I'm wondering if anybody has a good guess of what power I was making and what I'm goin to b making!! Thanks
I'm running a 420 mega blower with 2 750 holley's on gas heads have a little bit of port work and running 17/8's hooker super comp headers
Anybody
anybody
Not that simple
To get the answer you are looking for you will have to give an average previous quarter mile performance and MPH along with the vehicle weight to calculate your previous combination's power level. once that is known a guess on what to expect from your new stuff will have some foundation based on your vehicle's set up.
Any other path to your answer would require beer and lots of B.S. if you know what I mean. Bruce |
Well said Bruce! While I appreciate beer and a good bs session (bench racing), usually the results are dramatically different that real world performance......
Johnny |
[quote]well the 406 was in
my mustang and was goin 10.10 at 141 then I built my new full chaasis vw which weights 300 lbs less it went a 9.80 at 128 on a soft pass then I sPun a rod bearing and now my new motor is going to b the 427 but I don't have it yet the short block is suppost to b shipped out Monday the vw was doing 1.30 60's the mustang was doing 1.41 60's both running 28" mt's with 3.89 gears 400 th 4500 converter |
that helps
[quote="melson3086"]
well the 406 was in my mustang and was goin 10.10 at 141 then I built my new full chaasis vw which weights 300 lbs less it went a 9.80 at 128 on a soft pass then I sPun a rod bearing and now my new motor is going to b the 427 but I don't have it yet the short block is suppost to b shipped out Monday the vw was doing 1.30 60's the mustang was doing 1.41 60's both running 28" mt's with 3.89 gears 400 th 4500 converter Sounds like it may be fun to drive too. I hope this helps you out with your question. Bruce |
Thanks
Well the mustang only weighed 2800 lbs the bug weighs 2500 but over the winter I took the carbs apart to clean them I had one of my jets was out of the carb I knew it was supper fat but I just ran it that way I know where sum car performance calculators are but I was just wanting sum feedback about what anybody thought about my new combination any good or bad!
| All times are GMT -8. The time now is 06:12 AM. |
