-   -   bbc pushrod question (https://www.racingjunk.com/forums/showthread.php?t=27848)
taps 04-16-2010 01:34 PM
i am beginning to assemble my new dart bbc.it is standard dech height 9.8 with new afr 335 heads and solid roller.iput the heads on with a couple bolts to get an idea of valve clearance and pushrod length,my problem is i put the pushrods out of my old motor and one of those plastic pushrod length checkers and its way off i need a pushrod about .380 longer is this possible.
cepx111 04-16-2010 10:06 PM
Anytime you start out with a new combo rocker arm geometry has to be set, no matter what length you come up with.
Mine are about .250 longer than stock.
It's a little more envolved than that cheap plastic checking pushrod you got, it's best left to a competent machine shop.
Heres a 'MUST' read on the subject.
http://www.compcams.com/information/Products/Pushrods/
zipper06 04-17-2010 07:03 PM
For about $15.00 you can get an adjustable push rod from comp cams that will measure sm/blk and b/blk push rods and will help you set the proper geomerty.
Tod74 04-17-2010 07:12 PM
http://www.mid-lift.com/intro-mid-lift.htm
The only way to do it in my humble opinion.
The valve train on a Big Chevy is a nightmare anyway...so you want to be sure it is correct.
oldandtired 04-20-2010 07:10 AM
X all three above. After installing your heads w/gaskets, do the measuring.
Dave
