-   -   Carb Jets when using Nitrous (https://www.racingjunk.com/forums/showthread.php?t=27845)
jreiley 04-16-2010 03:16 AM
I'm going to add a 250 shot of nitrous to a sbc. As of the the jetting appears to be correct. When I install the nitrous, do I need to increase the jet size?
jmarksdragster 04-16-2010 07:15 AM
Jet the nitrous system for the fuel you need on when the switch is on, if you jet the carb it will be incorrect when not using it.
TS1955 04-17-2010 10:49 AM
Mark is correct. Leave your carb jetting alone. Jet your NOS accordingly.
TS1955
