-   -   Dart Almuminum head trouble (https://www.racingjunk.com/forums/showthread.php?t=27818)
dynaguy03 04-11-2010 05:47 PM
I got a call from my engine guy telling me he found the a problem with the valve guides on one head. These are older Dart 360 heads.
The actual valve guide bushing is loose in the head on 2 valves. How does something like this happen?. I am second owner of the motor, bbc 582..
Im guessing that the guide can be pressed out and an oversized O.D one pressed in?
Thanks in Advance
Keith
bbchevy 04-11-2010 09:06 PM
Guide
Keith,
Had the Same problem Years back!
We ended up making some Guides,the cut grooves for small snap rings on the top side,so that way it could NOT go down.Usually this happens if the Heads are either Real used up,and the material is getting soft,or there has been some Welding done and heads get Soft?
Later
G 8)
dynaguy03 04-12-2010 04:21 PM
valve guide
Thanks for the response...i have the head at the machine shop they are going to install new slightly oversized dia -.003 and press them in.
Yes these heads work well ..this motor makes 990 hp with my little tweaking i bet i can make 1000.
i went 7.55 ..so im looking to go 7.40's
thanks
Keith
