what plugs and gap
building a 540bbc blown alcohol engine
11.8 static comp. 731/726 lift roller //114 lobe center //running dur 322--326//dur at .050 284--288 brodix heads flowed to 372cfm on intake at 700 lift 12-71 blower 20%OD big&ugly injector hat port nozzles 110 pump mallory supermag111 trans;;pg with brake 1;80 straight cut gears 10 disc high gear 4;30 gears car estimated at 2800 lbs 32x14.5x15 slicks what plugs and what should i gap them at to do my first start-up? what hp do you think i'll be at? |
NGK 9's .025 gap
Zip. |
Re: what plugs and gap
11.8 static comp. 731/726 lift roller //114 lobe center //running dur 322--326//dur at .050 284--288 brodix heads flowed to 372cfm on intake at 700 lift 12-71 blower 20%OD big&ugly injector hat port nozzles 110 pump mallory supermag111 trans;;pg with brake 1;80 straight cut gears 10 disc high gear 4;30 gears car estimated at 2800 lbs 32x14.5x15 slicks what plugs and what should i gap them at to do my first start-up? what hp do you think i'll be at? Later ' G 8) |
| All times are GMT -8. The time now is 05:31 PM. |
