-   -   running 8:70 in the 1320 (https://www.racingjunk.com/forums/showthread.php?t=27787)
linumupscott 04-07-2010 04:04 PM
how much hp do i need in a 2900 lb car to run 870s?
zipper06 04-07-2010 09:57 PM
Your HP computed from your vehicle ET is 783.38 rear wheel HP and 870.42 flywheel HP
123car 04-18-2010 10:13 AM
Hey Zip, What will my 2350 lb car run with 875hp at the flywheel. Thanks, Mike
zipper06 04-18-2010 11:35 AM
Your ET / MPH computed from your vehicle weight of 2350 pounds and HP of 875 is 8.10 seconds and MPH of 165.47 MPH.
bowtie4542001 04-18-2010 01:44 PM
Hey Zip, can I play, what is the predicted E.T for 767hp at the flywheel at 2165lbs.
Thanks
Chris
zipper06 04-18-2010 02:03 PM
Thanks
Chris
HaHa, Chris with that short wheel base Opel, you're going too need a diaper/shorts change after the run.
Your ET / MPH computed from your vehicle weight of 2165 pounds and HP of 767 is 8.23 seconds and MPH of 162.75 MPH.
bowtie4542001 04-18-2010 02:49 PM
Thanks
Chris
Thanks a lot Zip
I will make sure I bring a couple pairs of shorts to change into. The gentlemen that had it before me was running some 8.40's with it. I will be glad to finally get it out to the track. I am redoing the wiring and cleaning up the engine bay before I install the new 418 sbc I got for it. I will keep yall informed.
Chris
123car 04-22-2010 11:48 AM
8.10 wow
Thanks Zip, Hey Chris I got ya covered By a Tenth. Mike
bowtie4542001 04-22-2010 04:32 PM
Re: 8.10 wow
Hey Mike, If we do what is predicted, we will both be flying :D
Chris
123car 04-23-2010 12:21 PM
Re: 8.10 wow
And both need diapers.
quote="bowtie4542001"]
Chris[/quote]
