-   -   Blown BBC Head Gasket, ADVISE? (https://www.racingjunk.com/forums/showthread.php?t=27786)
bbchevy 04-07-2010 01:49 PM
Heres the Deal?
427 T/Deck GM Block.
NO O-Ring Grooves,this Motor was in a Nost.Funny Car,and Ran Pretty GOOD!But,with Only 8-Passes on the Combo its a Hard Call?
Currently I have a set of Merlin 345 Iron Heads(VERY HEAVY)but a Good Head for a Blower Combo!
Heres My Delema?
This is going in my 95 S10 Back/Half Truck,standard Cab,so theres NO Room to Slide the Motor back!
I have a chance to pick up a Nice set of Edelbrock Chapman Heads (ALU)so that about a 150lb Swing.
The Motor had a set of Cometic Gaskets,that were sealing just FINE!
If I go with the Alu.Heads?
Will the Cometics be the Ticket?
OR?
O-Ring the Block and go COPPER?
Which is the Way I all my Old Motors were.But?That was before these Cometics were Invented?
Any Thoughts?
Thanks!
G 8)
markdunlap 04-07-2010 04:12 PM
Blown BBC head gasket
Look into SCE titan head gaskets. Copper with seal ring made into them. No need for o ring groove and have silicone beading around water holes.
zipper06 04-07-2010 08:39 PM
Re: Blown BBC head gasket
X2, i use them.
bbchevy 04-08-2010 06:37 AM
Gaskets
So,My take so far is go with the SCE Copper Gaskets over the Cometics,with Aluminum Heads.
THANKS fo the Input,Fellows!
Later
G 8)
markdunlap 04-08-2010 01:46 PM
Blown Big Block head gasket
I did not mean to down grade the Cometic gaskets. In fact I ordered a set today. I was just trying to offer an alternative to having to o ring the block.
The Cometics do require a very precise, fine finish deck surface on the heads and block to work. They do work fine if that is done.
hammertime 04-08-2010 02:22 PM
cometics here been fine for 4 re-uses :)
