-   -   Hair line crack in SBC block (https://www.racingjunk.com/forums/showthread.php?t=27773)
qtrmile2 04-06-2010 04:55 AM
Anybody have any suggestions on repairing a hair line crack in a block when it's in the car. Looks like the crack is on the passenger side 1 inch to the right and left of the 1/8 pipe thread drain plug on the passenger side on a SBC motor.
I drained the block, blew air in the radiator to help dry the area and get all the anti freeze and water out, brake kleened the area, peened on both sides of the crack to help stop it from cracking more, wire wheeled the crack then ground the crack to help when I put JB weld on it. I'm letting it dry with a drop light on it for 15 hrs.
Anybody have a different way or do you think this will work? Oh, I also will fill it with water and aluma seal then run a 5# radiator cap.
Thanks for your help.
zipper06 04-06-2010 10:59 AM
Vince if you reach it easy you can weld it with NI-ROD, just V it out preheat it with a torch and weld about 1/2" at a time, if it's just a tempary fix i'd run the block sealer.
The 400 blk 377", that i have in my Malibu has a 4" crack 3/4" below the deck on the passeneger side. It wasn't caught during the build, the blk wasn't decked. I v'ed it out and Tig welded it without pulling the heads. I'd weld about 1/2" and pean it too relieve the stress then weld another 1/2" with NI-ROD. It has over 200 passes on it and running a 16# cap. Course when i pull it apart next time ill change the blk. out. This was done as quick fix and it's been running for about 5 yrs.
oldandtired 04-06-2010 11:05 AM
x2 on the high nickle rod. I've done it before. Dave
qtrmile2 04-07-2010 07:12 AM
Thanks for the help guys.
TheYellaBrick 04-08-2010 05:59 PM
Man, I learn something new here every day !!
