-   -   dominator (https://www.racingjunk.com/forums/showthread.php?t=27769)
rich970 04-05-2010 03:36 PM
dominator
I have a question is there a feeler gauge setting for the dominator throtle plates as a starting point ? i thought i read it somewhere . Thanks
jmarksdragster 04-08-2010 02:07 PM
Not a feeler gauge, but you should have around .020 exposed on primary and secondary. They will look like little squares. If you have to raise the idle speed a little, work the secondary first. If you have to go to much because of a large cam/low idle vacuum AND the making sure the timing is optimized, you will need to drill small holes in the throttle blades to add idle air without excessively uncovering the t-slots. Start with a 3/32 hole in the primaries, add secondaries if needed. Best position is directly below the idle discharge port as shown below. "X" marks the spot.
http://i287.photobucket.com/albums/l...atorBottom.jpg
