-   -   brake problem (https://www.racingjunk.com/forums/showthread.php?t=27761)
ssmonte70 04-04-2010 01:01 PM
brake problem
i have a 70 monte put new rear drum brakes and new disc brakes in the front, when i got the car it only had the master cylinder i put the brake booster, i blead the brakes and not geeting a good pedal will it help to hook up the vacuum line from the booster,
fla1976 04-04-2010 03:35 PM
Power brakes won't work correctly without the vacuum line attached and the engine running.
ssmonte70 04-05-2010 07:46 AM
brake problem
weres the best place to pick up the vacuum from
oldandtired 04-05-2010 12:13 PM
Intake manifold...
Good luck, Dave
