302 sb....
Ive got a 302 efi that has been converted to carburated. It has a new mild cam. Since it was originally runnin an electric fuel pump..... there is no place to mount the mechanical fuel pump. Anybody had any exp with this.....any suggestions would be much apporeciated.
302
RUN A ELECTRIC FUEL PUMP WITH A REGULATOR.... GOOD LUCK....
Not legal... Gona have to figure a way to get a mechanical pump to work.
thank you for the reply |
If it has to be a mechanical pump, the only option will be a belt driven pump, but you have to mount a cell up front for that. If it has to be a stock type pump you will need a different block.
I was sure hopin that wasnt gonna be the answer. I had started to figure that was the case though.
Thank you |
| All times are GMT -8. The time now is 06:25 PM. |
