-   -   CLEARANCE -73 Challenger w/ALTERKTION & MILODON Oil Pump (https://www.racingjunk.com/forums/showthread.php?t=27734)
ProEbody572 03-31-2010 01:08 PM
Anyone experienced CLEARANCE PROBLEMS using the MILODON H/V ALUMINUM OIL PUMP in a 73 Challenger with 572 HEMI and the AlterKtion Coil-Over Front End set-up?
I've been told that I may have clearance problems with the driver's side motor mount when using this oil pump and might have to change the mount set-up.
If anyone has used this combination in a Challenger please let me know.
THANKS, Scott in Michigan.
comp5168 04-04-2010 12:23 PM
oil pump clearance problem on 73 challenger
Had that problem before on a regular front end . Installed a front motor plate and then it all fits fine. This was for a drag race only application, not recommended for street use.
