Patriot Heads? 400 sbc on a budget.
Are theses patriot heads any good? Better than procomp? Im looking to build a low budget 400 drag racing only motor. Still stock rods and pistons, Any suggestions? on everything. Its going in a 95 s15. tubbed Reg cab shortbed. Thanx.
Same heads as ProComp same castings.
Zip. |
These heads are a much better choice.
http://www.profilerperformance.com/sbc-heads-176.html |
Carl, i like those heads, hadn't seen them before. The flow #'s are better out of the box than Brodix Track 1's, CNC ported by Brodix. Looks like they could be a good blower motor head in the solid version also. Thanks for posting them.
Zip. |
Zip. I have been looking at them for quite a while and considering them on some of the up coming builds. |
I did a 350 budget engine & chose to use patriot heads over the procomps because they were a better looking casting, although both are cast in China I believe. I bought them bare & added my valves etc that I already had. overall I am happy with them.
I'd like to see a set of patriots on my flow bench. Looking at pictures I can find on the web, I'm just not seeing 295CFM. Overall port design leads me to believe they would be right around 260 out of the box.
Zip. |
Re: Patriot Heads? 400 sbc on a budget.
AFR heads are an awesome head out of the box.. Dart and RHS are a good strong second. |
Got a set of procomp 210 heads on my 406 with manley hard ware work great very happy. :D
| All times are GMT -8. The time now is 04:45 PM. |
