-   -   BODY LEANING (https://www.racingjunk.com/forums/showthread.php?t=27662)
JEFF69Z28 03-24-2010 04:09 AM
BODY LEANING
AFTER I GET OUT OF MY CAR IT SEEMS TO BE LEANING TO THE DRIVERS SIDE.I PULL UP ON IT AND IT LOOKS OK .WHATS UP WITH THAT .COMP.ENGINEERING 3 WAY ADJUSTABLE SHOCKS ON REAR WITH HOTCHKISS 1.5 INCH DROP SPRING.FRONT HAS SAME SHOCKS AND SPRINGS,86 MONTE CARLO.DOUBLE ADJ.UPPERS AND LOWERS ON REAR.
TheYellaBrick 03-24-2010 07:24 AM
You have some binding going on within the suspension pivot points.
DRY ?
Very new and too tight ?
JEFF69Z28 03-27-2010 04:01 AM
DRY ?
NEW LOWER CONTROL ARMS,IS THERE A TORQUE SPEC FOR THEM?SHOULD I BE IN THE CAR WHEN THEY ARE TIGHTENED?THERE DOUBLE ADJUSTABLE WITH QA1 ENDS
