poor idle
A friend of mine just received his new motor 440 mopar edelbrock performer heads, 11:1 comp, not sure on cam specs but I no its the largest solid flat tappet that mopar performance makes, single plane intake with a 1050 dominator.
The problem is we cant seem to get a decent idle, seems like a lean backfire but burn your eyes out its so rich. It clears up nice after mid range right up to max rpm. on the way back down it takes a long time to get to idle, then stumbles and stalls, if you try to give it throttle it backfires! we changed to a 850 with a little improvement but not much! it also takes along time to get to temp. I'm thinking cam timing? or vacuum leak? Thanks Kirk I KNOW............ ITS A MOPAR :? :roll: :? :roll: :? :roll: :? |
| All times are GMT -8. The time now is 10:26 PM. |
