-   -   Installing new floor pan, transmission tunnel and firewall (https://www.racingjunk.com/forums/showthread.php?t=27636)
jreiley 03-20-2010 05:20 AM
I would like to put this stuff in my 67 camaro. I don't have a clue as to the sequence of doing this or rather to use aluminum for the floor or steel. A real beginner. Any help would be appreciated.
lively 03-20-2010 01:42 PM
IF YOU HAVE PATIENCE--WILL LISTEN TO OTHERS ADVICE AND NOT BE-- AFRAID OF GETTING DIRTY/CUT UP/AND SMASHED FINGERS ---YOU CAN DO IT AND BE HAPPY WITH YOUR WORK :lol: :shock:
DO NOT BE AFRAID TO ASK ??????????
LIVELY
dragonmaster093 03-20-2010 08:20 PM
x2
also i would suggest the steel and get it in 1/2 sections ie fronts and rears (with tunnels in) and brace doors and side to side to prevent body flexing
jreiley 03-21-2010 05:27 AM
How do the floor pans attach to the frame or do I need to build lips out from the frame to attach them? Also do I do the firewall first? Thanks.
johnracer 03-21-2010 06:45 AM
Is it still a unibody/subframe connector car or does it have a full chassis?
If it's unibody, I wouldn't cut out any of it unless you plan on welding in stock replacement parts because the floor is the frame from the front suframe back and any roll bar/cage is attached to it.
Why are you replacing the floor? Rust or weight? If it has a full chassis, and you plan on replacing the firewall, I'd do it first, then build the floor. It'll need aome sort of x-bracing under it for support and attachment.
Johnny
dragonmaster093 03-21-2010 09:07 AM
if using stock replaceents order them the over lay mark out the dementions then leave 1/8 or ore for final triming but make sure to brace up body. my opinion is pans first then fire wall
jreiley 03-22-2010 07:53 AM
The frame/chassis is stock. The most important part to replace in reality is the transmission tunnel and the firewall. I can live with the floor pan. No rust.
