??carb for small block chev. 360??
I am getting ready to get my engine back from machine shop,.060 350 11.10 compr. small block, solid roller cam. Its going in a street/strip car...My carb. I have now is the 4779- 750... My question is , is it worth the money for me to buy an HP750, cam specs.
@.050 Int. dur. 246 Exh. dur. 253 Int. lift .585 Exh. lift .600 I never have owned a good carb. do they make that much of a difference. I know I left out alot of other info, Just trying to compair the two carbs... Thanks guys for any help |
i have simular engine and all i had at time was 600 and its way to small have checked around and everyone says hp 750 is what i need so i thought id pass it on to you
CALL PRO SYSTEMS OR AED THEY WILL SET YOU UP WITH EXACTLY WHAT YOU NEED.
I will look up pro-systems on google,Hay guys, Thanks so far for the help
PRO SYSTEMS YOU WONT BE DISSAPOINTED!
I contacted Pro Systems, They sent me back an email explaining what they could build for me and what it would cost... I am VERY impressed, and the cost is very resonable... Hay THANKS you guys looks like I found me a carburetor...
| All times are GMT -8. The time now is 09:38 AM. |
