-   -   crank choice (https://www.racingjunk.com/forums/showthread.php?t=27570)
bigcrunch 03-10-2010 05:08 PM
crank choice
13-1 compression, 10-15lbs boost, alcohol fuel
Scat 4340, eagle 4340, gm forged ??
this is for a spare motor, I don't have the fuding for a crower, moldex, bryant,,,,
gnsrule 03-10-2010 05:55 PM
Ok, I'll bite...
13:1 w/ 15 lbs of boost on alky. Sounds like you really should have the Crower, Moldex, Bryant, etc..
Craig
cepx111 03-10-2010 07:32 PM
Ok, bite #2
Is it a big block, small block, ford, chebbie?
zipper06 03-10-2010 08:43 PM
How big is the blower, IE: b/blk or sm/blk, rpm range? From what i've been reading Scat has a better handle on the inspection, although both cranks are the same varity (Chinese)
I've run both in sm/blks with good luck (so far)
bigcrunch 03-11-2010 06:09 AM
BBC tall deck, 8/71 with striping and anodized. 6000rpm max on this one.
bigcrunch 03-11-2010 06:53 AM
Anyone have experience with this brand?
http://www.ohiocrank.com/chevybb_cranks.html
TS1955 03-11-2010 09:14 AM
A friend of mine has one in a 526 blown big block chevy. Oddy dynoed it at 2200HP. He has ran it one season so far in a rail buggy.
TS1955
bigcrunch 03-11-2010 10:32 AM
TS1955 which crank the Ohio 4340 or their billet?
zipper06 03-11-2010 12:01 PM
Same as the Eagle or Scat in the 4340 version ( Chinese imports) although the Billet may be American made.
Here is a couple good reads on crankshafts, i realize they're talking about Chrysler cranks, but incluces all the crankshaft companies.
http://forums.racingjunk.com/viewtopic.php?t=13515
http://www.forabodiesonly.com/mopar/...ad.php?t=90763
cncmotorsports 03-11-2010 01:27 PM
Callies Dragon slayer would be just fine for you. USA Made
Depending on your stroke they start at $1050.00
Anything cheaper than this is a Chinese crankshaft
