which headers and heads sbc combo
I don't know enough about flow# but I know using a flat tappet has its limitations, so using only a flat tappet what heads,headers, and modifications would you use with the current combo for an improvement:
383 sbc,hooker super comp 1 3/4 #2131 headers,comp .558 550,260,266 at .050,108 on 104 icl,13.6-1,dart iron eagle 215 platinums,2.05 1.6 valves bowl blended and port matched to a 2925 super victory,alky 810 carb,power glide,4.56 gears,4800 convertor,3100 lb car.This is a 1/4 drag car. |
have you ran the car with that setup yet if so what kind of numbers 60' 1/8 mile 1/4, mph.
10.32 at 130 mph
Sounds like it runs pretty good for what it is.
I really can't complain just seeing if theres more without spending a bunch of money
man the only thing i would try is a solid roller cam. but your car runs great just the way it is.
Those are some good numbers no doubt. 10.30's aint nothing to sneeze at.
BUT: Comp Cams makes a 630/630 solid roller, with this cam I wouldn't be afraid to say that you'd be well into the 9's. Cp |
BUT: Comp Cams makes a 630/630 solid roller, with this cam I wouldn't be afraid to say that you'd be well into the 9's. Cp JMO Zip. |
Well dont tell me John, tell him - He's the one not content running 10.30's not me>?
But as far as your cam change? It just goes to show, some tenths cost more than others and that you never know what works till you try it, right? I'm sure it wasnt the first time you made a change and didnt gain much, I know it's happened to us all at one point or another. Cp |
But as far as your cam change? It just goes to show, some tenths cost more than others and that you never know what works till you try it, right? I'm sure it wasnt the first time you made a change and didnt gain much, I know it's happened to us all at one point or another. Cp Zip. |
| All times are GMT -8. The time now is 05:37 PM. |
