-   -   regulator (https://www.racingjunk.com/forums/showthread.php?t=27468)
spib 02-24-2010 02:39 PM
regulator
I was told by a company that I just got a regulator from to not mount regulator, just plumb in line, up close to carb
he said vibrations when you mount a regulator will kill them
agree or disagree ?
my set up is single carb, 8an line 600 hp motor, no return line
gnsrule 02-24-2010 04:08 PM
I mounted mine on the old car and never had a problem. Im trying to find a good spot right now to mount it on the new car but havent found the right spot yet.
Whos regulator did you get? If its a BG 4 port, place a lock washer under the mounting bracket bolts if you use it as the supplied bolts are too long and doesnt squish the diaphram down tight. It will leak. I speak from experiance on this one. I called BG last time and they told me they never seen that before and now 4 years later I buy a new one and see the same thing.
Craig
spib 02-24-2010 04:13 PM
Its a moddified holley I believe from pro systems carb, looks like my small reg I got with my blue pump but it uses 1/2 inch in and out
http://www.prosystemsracing.com/cata...92/5339867.htm
mopar1968 02-24-2010 06:37 PM
Mine is mounted on the firewall, with line to carb, no problems :!: :!:
''JUST MY TWO CENT'S WORTH''
zipper06 02-24-2010 07:55 PM
Mine is mounted on the passenger fenderwell, when running gas with 2 #6 lines going too the carb. I have a duel setup with a 10 gal tank in the trunk and a 3 gal. for alcohol mounted left front for the injection.
gnsrule 02-24-2010 11:38 PM
[quote="mopar1968"]Mine is mounted on the firewall, with line to carb, no problems :!: :!:
I belive NHRA sais no fuel line can be within 2 inches of the firewall, for what its worth.
Craig
spib 02-25-2010 10:30 AM
[quote="gnsrule"][quote="mopar1968"]Mine is mounted on the firewall, with line to carb, no problems :!: :!:
Craig[/quote
6" I believe :D :D for regulator, they get that I believe with the fact it states must be 6" forward of flywheel, bell housing area
mopar1968 02-25-2010 07:47 PM
If you look at the pics in my profile you will see it mounted in passenger side of firewall, goes thru tech at every race, we race NHRA Track.
http://www.racingjunk.com/gallery/profile/163312/181736
al34 02-26-2010 07:00 AM
:wink: That is correct I got hit in tech 2 years ago for having the reg on the fire wall and had to relocate it.
spib 02-26-2010 07:09 AM
mark I used to have mine just like yours, first race they made me move it, some tracks are just not that picky
