powerglide questions
Hello All:
Looking for some opinions from the powergide pro's. I was having issues with fluid leakage from the rear seal.When the boys rebuilt my glide they said the rear cover was tore up. 235 " rear engine dragster hard tail shortyglide w/brake I did feel the car bounce going on the stop and also had issues with tire/spin tire/chatter from 330 on. ( off the stop) Question Did this issue occur from tire bounce/spin? Do i have a alignment issue occuring? Do i have no idea what i'am talking about! (best answer) Any Opinions Thanks Mike |
Mike is this a coupler or driveshaft ?
I've never seen bounce/spin cause a issue before, I've ran some crappy tracks with hardtails and never had a issue. Is it just leaking around the seal itself ? |
Mike
You very well could have early signs or alignment issues. I spent some time talking to Don Higgins from Crew Chief Pro. His car had a slight bend in the rear frame. This took the rear out of alignment and tore up a lot of things. I would check for square as a start. Will the bounce hurt it, not most likely the case but I would not rule it 100% out. Have you had your builder take a look to see if he can offer up some advice? |
Guy's
Started to tke things apart and yes it is a alignment issue. Old Old hardtail car with coupler.I think also there may be a rail that bent. I will get it apart this weekend and resquare the motor/trans new mounts etc and keep saving for a new car in 2011. Thanks all Mike |
If you replace the rear seal after alignment issues, replace the rear bushing also,(or is it roller) doubt it.DR.
Had to replace the rear cover, seal, bushing, so the boy's threw a kit in it also. hopefully i cured the alignment issue, will see what the next racing weekend brings
thanks Mike |
Does the coupler slide in and out of the yoke with no bind when the car is sitting on the rear wheels?
Sorry for the delay, been racing.
After i cut the mid mounts out and realigned ,yes i can slide the coupler.I was able to before, but i think i tweaked the rail. I have now reenforced it and so far (6 passes), everything is looking great! Now if i can just convince my wife i need a new car! Mike |
I see your from Arizona. Maybe its not necessaraly a new car you need, but a new track. :shock:
Oh No!
Any chance you were at the Firebird Div? What a mess! |
| All times are GMT -8. The time now is 07:56 PM. |
