very simple question for you experts
holley fuel pump what is the actual fittings that go into the pump? an???? not that familar with the an fittings thanks
fuel pump
not sure which pump you have but a good many of the holley pumps take 3/8 NPT and then there are some that take 1/2" NPT.
its a holley blue electric
MY HOLLY BLUE IS 3/8 NPT(PIPE THREAD)
X2
3/8 npt |
so any pipe thread 3/8 will work ? i have been using 3/8 brakeline any way to tie into that or just put a nipple on and put a rubber splice?
Your asking two diff questions now. A 3/8 brake line will not fit a 3/8 npt, a pipe thread has a tappered thread pitch. Are you asking if you can use 3/8 brake line as the fuel line? Sure, if you attach some sort of 3/8 hose in between or find two 3/8 inverted flare bushings to put in ur pump.
AN fittings are the tapered seal, streight thread fittings commonly used on the fancy red and blue fittings and anything also commonly reffered to as JIC.
thanks for clearing up!!!!!!!!!1
| All times are GMT -8. The time now is 10:59 AM. |
