-   -   Cooliong system (https://www.racingjunk.com/forums/showthread.php?t=27286)
mooneye777 02-07-2010 08:38 AM
Cooliong system
What is everyones choice for a track only cars cooling system. Tap water, Deionized water, disstilled water. Or is there some other top secret fluid that is made for todays race car that is better?.
dragonmaster093 02-07-2010 08:47 AM
circe track we been using water wetter and anti freeze some use it with water
TheYellaBrick 02-07-2010 09:00 AM
We are NOT ALLOWED to use ANY amount of Anti Freeze at our pavement ovals. I don't know about you dirt trackers though.
Water Wetter and H2O and then drain the COMPLETE system in the fall.
zipper06 02-07-2010 09:42 AM
NO ANTIFREESE, in NHRA or IHRA, in fact it will get you tossed out and no return of your entry fee if it's detected in tech, or if you spill any on the track.
dragonmaster093 02-07-2010 10:46 AM
wasnt sure on pave and drag just what i know on dirt. good to know for other forms of racing
hammertime 02-07-2010 11:38 AM
anti-freeze in mine until end of may then I just go with water from the hose nothing else.
cepx111 02-08-2010 06:56 AM
50/50 antifreeze for now, will drain most of that out sometime this spring when it finallys warms up and theres no threat of freezing, then I'll switch over to water wetter/tap water & whatever antifreeze is left in the block.
Cp
johnracer 02-08-2010 10:49 AM
Just tap water.....drain completely in the winter and run RV antifreeze through it just in case. Flush & refill with tap water in the spring.
Johnny
slowmotion 02-08-2010 12:34 PM
Filtered water from a car wash. It's the purified water they use in the spot free rinse.
gnsrule 02-08-2010 02:48 PM
Cp
If you ever run over your own water/antifreeze, you'll wish like hell you got ALL that slippery green stuff out
