-   -   16 volt battery (https://www.racingjunk.com/forums/showthread.php?t=27214)
63split 02-01-2010 08:47 AM
16 volt battery
Can anyone please tell me what's involved in changing over from a 12 volt battery to the new 16 volt batterys.
thanks for your time.
shawnp 02-01-2010 09:09 AM
We simply purchased a new battery and charger. We sent out our alternators to Mark Payne and he converted them over to 16 volt. I believe the battery and charger thru Summit Pro Shop is about $450 and you are looking at about $75-$100 to convert an alternator.
andamo 02-01-2010 11:14 AM
Shawn, do you run a alternator on the dragster ?
hammertime 02-01-2010 11:25 AM
x2
I am in the middle of trying to decide to swap to 16v or buy another 12v battery choices :shock:
shawnp 02-01-2010 01:03 PM
Absolutely. :D
I972Nova 02-01-2010 03:54 PM
Re: 16 volt battery
Just bolt in the batt / alt and go.
I called PowerMaster tech today concerning an alternator with 16 volts and they assured me that I wouldnt need the step down or anything. The alt puts out 18.9 volts and wont hurt anything, you dont get into trouble unless your over 20 volts.
I ran the 16 volt last year with no alt and it worked good, but later in the rounds was missing the alt for sure. I just picked up a Powermaster 140 amp alt and should be good to go now...
Hope this novel is helpful...lol
hammertime 02-01-2010 07:36 PM
You guys thinking of going to 16v check out this site
http://www.batteriesareus.com/index....x&cPath=65_146
12/16v lite weight deal for 190.00 looks like a great deal
Also make sure everything you have is good for upto 19v's before swapping... I'll be sticking with 12v again because of this. hmmm now what 12v to buy ?!?
shawnp 02-02-2010 05:13 AM
Dave,
What do you have that won't work up to 16v?
hammertime 02-02-2010 05:56 AM
Dave,
Not that it may not work but the Relay Board I've asked he said 18.5 max .. I asked on YB and he said it'll be ok but searching I did on there no one runs a alt with it (my guess because they dont want to chance it)
shawnp 02-02-2010 09:24 AM
For K&R? We were told directly that the 16v would not create any problems with any of the K&R electronics.
