-   -   Coil Springs (https://www.racingjunk.com/forums/showthread.php?t=27176)
smitty80 01-28-2010 06:47 PM
Coil Springs
I have an 80 camaro with a 383 with 600hp and weighs about 3000lbs and has a powerglide also just wandering if anybody out there has a suggestion about what is a good front coil spring to run right now it has a stock bbc spring in it thanks
zipper06 01-30-2010 06:36 PM
Don't know if it will work for you but i've always put the lightest spring possible and used 90/10 shocks IE: 6 cylinder springs. seems to transfer weight better.
TheYellaBrick 01-31-2010 05:03 PM
What is your PRIMARY use for this hotrod ?
