fuel presure gauge test
Does anyone know someone that can test Fuel gauges or is there a way I can do it, I have three 1.5'' gauges and all three of them show a different presure one shows 5# one shows 7# one shows 9# at the regulater these are all new gauges. I hate to keep buying them because now I wouldn't know if any of them are correct.
Thanks Andy |
Re: fuel presure gauge test
Thanks Andy A Liquid Filled Gauge(QUAILTY)! Later G 8) |
A liquid filled gauge is good only if the inside movement is vented to the atmosphere. Most automotive type gauges are not vented. The atmospheric pressure in the gauge can cause significant errors in low pressure gauges. The outside barometric pressure and temperature changes make them less accurate. They were designed to give stable reading moreso than accurate readings. They are used on pumps and equipment that have extreme vibrations. An accurate gauge will be accessible from the outside so it can be adjusted during calibration. Most automotive gauges are considered disposable.
well it sounds like I'm not the only one that has had this problem. and 2 of the 3 gauges I have are liquid filled. and from my understanding the liquid is only to keep the needle steady. my non filled one is steady as the liquid filled ones. and Hammertime you may have something there with the heat. mine changed bad after the engine heated up and I made a run. is there any way of testing them to see if they are correct.
Andy |
Andy |
Outside of bringing it to a calibration laboratory, the best you can do is to compare it to another gauge. If you know someone with a gauge that is accurate, you can hook them up on a "T" and compare them to see how they correlate. Not really calibrated, but it will give you an idea of the accuracy.
Gauge
Personally,CARBS are for LAWN MOWERS! 8)
Injection! ANYWAY? I think that the Placement of the Gauge also has ALOT to do with the Setting(Could just be Me)? I Like the Gauge at the Fuel Inlet to the Fuel Mixer(CARB)Put the Gauge rite at the inlet of your Split on the Carb inlet.I have Found this to work MUCHO Better! And its OBVIOUS that when the Oil in the Gauge warms up it will Drop!Does your Oil Pressure Drop when it reaches 200*? Later G 8) |
Thanks Guys for your time. I'll find someone that knows he has a good gauge and test mine with that.
Andy |
| All times are GMT -8. The time now is 12:13 AM. |
