fastest trans brake on the market
Im looking to upgrade the trans, as well as getting the quickest trans brake possible, need some feedback here,,who has the quickest stuff on the market for a glide ? as well as the best bang for your buck on a trans....
For a new glide and wanting the fastest brake possible, call Marco and talk to him. See what he says. He has a dyno in the shop and I am sure he can tell you how quick his stuff is.
http://abruzziracing.com/main.html |
call tim at ptc
http://www.ptcrace.com/index.php excellent service, have heard nothing but good from them!!!!! |
Re: fastest trans brake on the market
Shawnp, i totally respect your ability and knowledge and you are one of the smartest persons on this forum bar none. Now back too the question, it all depend as i said before on the car weight, HP, and the gearing. I have worked with a car weighing over 3,000 lbs with a 1.76 gear and 6.20 gears for the 1/8 mi. running 1/8 mi. running the 7.0 class heads up. I have made 1/2 doz. different release valves, different undercuts, longer and shorter, closer to the back and front of the valve, different spring pressures. I'm happy to say that the car can go red on a 4.0 tree, no trans builder will guatentee this, with a run of the mill trans. Spid made a wise choice with the PTC trans. Kenny ford was the National 7.0 champion with his Camero and he also runs a Malibu wagon that weighs about 3400 lbs in the pro tree class. You can't buy a trans that will guarentee a 4.0 reaction , forgot to add that the 1st gear is a big factor, Kenny Ford runs a 1.96 low gear Zip. |
Zip,
The reason I suggest Marco is for the info he has on hand and what he can test. Marco's trans dyno measures pressures and I am almost positive can capture the reaction speed of the brake making sure that the fastest brake can go into the application. Not many builders have this to offer. It is just slap them together and ship them out. |
Originally Posted by shawnp
Zip,
The reason I suggest Marco is for the info he has on hand and what he can test. Marco's trans dyno measures pressures and I am almost positive can capture the reaction speed of the brake making sure that the fastest brake can go into the application. Not many builders have this to offer. It is just slap them together and ship them out. Zip. |
Zip,
The reason I suggest Marco is for the info he has on hand and what he can test. Marco's trans dyno measures pressures and I am almost positive can capture the reaction speed of the brake making sure that the fastest brake can go into the application. Not many builders have this to offer. It is just slap them together and ship them out. Zip. on the topic ... IMO Coan makes the fastest one I've ever used, my non pro brake Coan is as fast (more delay) as my pro brake Abruzzi/Hipster/BTE |
Zip,
The reason I suggest Marco is for the info he has on hand and what he can test. Marco's trans dyno measures pressures and I am almost positive can capture the reaction speed of the brake making sure that the fastest brake can go into the application. Not many builders have this to offer. It is just slap them together and ship them out. Zip. on the topic ... IMO Coan makes the fastest one I've ever used, my non pro brake Coan is as fast (more delay) as my pro brake Abruzzi/Hipster/BTE I don't have these features and i leave on the last yellow and roll .040 in the box and hope i don't go red. I'm too old to catch the top light all the time and the last yellow gives me time too adjust/see the tree. The last time out i went .487 red so i guess i'm never going to get it right all the time. This is turning into an intresting thread. Zip. |
Zip,
This is good, I`m liking all this comparision, makes it easier in determining my final choice. I dont have the time or money to be testing all these myself, thanx. looking forward to more great feedback..
| All times are GMT -8. The time now is 01:06 AM. |
