New Lifters and Assembly lube
Hello All
I im installing Isky Red zone extreme duty roller x lifters.. the instructions say do not soak them in anything..just clean the body of the lifter and use oil or assembly lube on the body only. Whats the best lube to use on the lifter body?? Thanks Keith |
Any moly 'based' assembly lube will work, cam break lube works good too.
Coat the body, roller, and put a dab where the pushrod meets the lifter. Cp |
Coat the body, roller, and put a dab where the pushrod meets the lifter. Cp JMO Dave |
| All times are GMT -8. The time now is 05:45 AM. |
