-   -   sbc (https://www.racingjunk.com/forums/showthread.php?t=27120)
bigmack 01-24-2010 02:22 PM
sbc
hey guys i just was wondering if anyone was racing with a 383 sbc and what you guys was shifting the engine at. i was talking to a friend and he said he was shifting around 7200 and 7300 with his 383 i have never shifted my 383 over 6800. let me know what you guys shift at thanks mack.
mopar1968 01-24-2010 02:35 PM
Well i run a small block Mopar and i shift it @ 7400 rpm all day long :!: :!:
''JUST MY TWO CENT'S WORTH''
bigmack 01-24-2010 04:32 PM
can't wait for the track to open and try shifting it at 7200 or ????, car went 11.07 shifting @ 6800 rpm, hope to get it in the 10's this year.
johnracer 01-24-2010 06:12 PM
What do you have for a cam and heads? That'll determine where you should shift.......
bigmack 01-24-2010 07:00 PM
the heads are pro actions 235 208 int 160 exh the cam is comp 630-630 solid roller, but i also have a comp 675-645 solid roller which one would you go with. oh yea the trans is p/g 1.76 ford 9" with 4.71 gears 28x10.5x15's m/t slicks. in a 87 camaro around 3200 pounds.
zipper06 01-24-2010 08:34 PM
@ 3200lbs i'd stay with the cam you have in it .630/.630 for the low end torque.
bigmack 01-26-2010 05:46 AM
thanks for the replys guys and good luck this year and be safe.
fullspeed383 01-28-2010 02:52 PM
hey bigmack how are your 60 foot times with your combo.
bigmack 01-28-2010 03:29 PM
it's in the low 1.5's hope to get it down in the 1.4's this year
fishman1 01-28-2010 03:54 PM
I would guess with 235 heads and if your cam will rev to 7300-7500 rpm, that is were these heads would have to be to take advantage of that big a head........my 383 sbc with afr 210 heads peaked on horse power at 6800 rpm and my camshaft is good to 7400 rpm.........so i shift out of first gear at 6700 rpm with my glide and go through the traps at 7000 rpm.....works for me, but if i have 235 heads i would have to rev it way higher to gain anything
