new engine build question
I just picked up a 302 block and the only numbers I can find on it are F1SEBB.Does this have hyd. roller in it?This will be my first build, so I'm going through alearning process.
I came up with a 87-96 truck 5.0 block
With the intake off you can tell real quick, even with no cam in it, there will be bosses where the lifter retaining assembly bolts too. Most all 85 up HO GT and 5.0 LX motors had roller cams, everything else 87 up. Cp |
| All times are GMT -8. The time now is 04:49 AM. |
