-   -   INTAKE MANIFOLD (https://www.racingjunk.com/forums/showthread.php?t=27103)
JEFF69Z28 01-23-2010 04:18 AM
INTAKE MANIFOLD
DOES ANY MANUFACTURE HAVE AN ADVANTAGE OVER ANOTHER,I HAVE A SUPER VICTOR PORT MATCHED ON MY SBC,WILL DART OR ANY OTHER MAKE MORE HP?
JimmySmith 01-23-2010 05:19 AM
manifolds
Give us some specifics on engine ,car ,shift rpm and mabe someone can help. Also intended use Later J.Smith 4621 racing
hammertime 01-23-2010 05:22 AM
need more info ..
but can say the super victor did not impress me on any sb I ran it on.
JEFF69Z28 01-23-2010 08:25 AM
Re: manifolds
406,SOLID ROLLER CAM,850 HOLLEY,8 INCH CONVERTER,4.56 GEAR,86 SS MONTE CARLO,SHIFT AT 7100 RPM,GO THRU TRAP AT 7100 RPM 128 MPH.
JimmySmith 01-24-2010 05:59 AM
intake manifold
My car 3200 lbs 360 mtr 220 heads, PG 5800 conv. , 5.38 gear, 31 tire runs .03-.04 quicker in 1/8 with a Holley 300-2 over a Vic Jr. never did compare on 1/4 my cam is [email protected] shift @6800 . Later J.Smith 4621 racing
hammertime 01-25-2010 06:16 AM
Re: manifolds
On my 383 and 434 the super victor was very slowed compared to everything else (including a ported Dart Wilson and a cheap Pro Products)
andybyrd 01-25-2010 06:23 AM
My 2 Cents -- I ran a super victor on my SBC 434 and A Dart with a Holley H/P 950 6.10 in the 1/8 super victor 6.09 yesterday with the Dart but the Dart is straight out of the box the Super victor was ported and had a lot of pollish work done on it. I think If money is no object buy both work both test them both then sell the one you don't want Here on RJ, If money is tight then I would buy the Super victor it is probably the best intake out there for it's price, thats just the way I see it hope it helps. be safe
Andy
curtisreed 01-25-2010 10:20 AM
Re: intake manifold
Is this a stick shift car?
Curtis
jmarksdragster 01-27-2010 11:03 AM
You didn't say what heads, that will make a difference. On anything roughly 200cc and smaller any of the larger intakes will be OK unless the heads are significantly worked over. For larger heads or well ported heads any intake can benefit from some work.
JEFF69Z28 01-28-2010 04:52 AM
AFR 210 FULLY CNC
