-   -   67 Camaro coil over shocks for the front suspension (https://www.racingjunk.com/forums/showthread.php?t=26943)
Harbone 01-09-2010 05:59 AM
I have a big block 67 Camaro that I want to take the front shocks and stock front springs off and replace with a set of coilover adjustable shocks. the front suspension is all stock except the spindles and wilwood brakes. want to be able to adjust my ride heigth so I can lower it at the track and bring it up for the street, any suggestions for a good manufacturer?
Thanks
I972Nova 01-09-2010 12:06 PM
I have Qa1 on my 72 nova and I am getting ready to order a set for my 70. They are 450 but very nice and adjustable. You can also adjust ride height with a spanner wrench.
Hope this helps...
cam67152 01-09-2010 05:23 PM
X2 on the QA1's there a snap to install and there is lots of ride height adjustment. They have a few different options, drag, street, single or double adj. I have them on my 67 street car and on my 67 drag car,
well worth the money.
cam67152
Harbone 01-10-2010 07:53 AM
thanks guys! the qa1's were the best I have seen on the net and other forums, just curious, how much actual heigth adjustment do you guys have??
I972Nova 01-10-2010 11:10 AM
without looking at the car I think it was about 3" total of threads. its been awhile since i put them on though...
Harbone 01-10-2010 11:48 AM
thanks Josh!
chevyfireball 01-13-2010 12:43 AM
I put a set of QA1 adjustables on my 69 Camaro. Fitted perfect.
oldandtired 01-13-2010 07:33 AM
A wise investment is the coil over thrust bearing kit that goes between the spring and pad. Much easier to turn the big nut.
$30 per pair from Speedway
$40 per pair form SW Race Cars
Dave
Harbone 01-13-2010 10:49 AM
so far I have price shopped everybody and Autofab has the best price. Plus their receptionist was the nicest lady in the world and Josh the parts guy is a tru professional. $467.00 for the kit with the thrust washers and wrenches plus $15.00 in freight, gonna order them up today!
TheYellaBrick 01-13-2010 11:11 AM
Chris,
You do realize that you'll need to adjust the toe every time you change ride height unless you have zero bump steer ?
