STORING CAR FOR WINTER
IS IT ALRIGHT JUST TO TURN THE MOTOR OVER ONCE A WEEK AND EVERY ONCE IN AWHILE FIRE IT.
There are a bunch of different ways ...this is what i do ..
If the car is on gasoline- start it up and i spray "Engine store " like crazy into the carb till the engine starts to smoke alot and cough a little . I like to have the tires off the ground too. Then every once in awaile i just "bump the mtr over so the same spring isnt being compressed. I also ..which some here will disagree .. use "Sta-bil" in the gas. I have never had a single problem. I also keep a battery maintainer on all winter. If this is Alcohol .. its a whole different animal .. Hope this helps Keith |
I JUST CALLED VP RACING FUELS AND THEY SAID THAT THERE FUEL(VP110) WILL NOT VARNISH LIKE REGULAR GAS,SO IM GOING TO RUN IT EVERY ONCE IN A WHILE UNTIL IT RUNS OUT,MAYBE A GALLON OR SO LEFT IN TANK.THENJUST TURN MOTOR OVER ONCE A WEEK TO KEEP PSI OFF OF THE SAME SPRING.
Originally Posted by dynaguy03
If this is Alcohol .. its a whole different animal .. Keith seems much easier then gas :wink: |
Winter storage
David..
Oh yeah... sure.. "Its all good man" |
| All times are GMT -8. The time now is 03:56 AM. |
