-   -   th 350 problems (https://www.racingjunk.com/forums/showthread.php?t=26884)
SkylerFaoro 01-02-2010 11:13 AM
th 350 problems
I have a th 350 and finished install last night drove great went to drive today goes into gear but only moves at higher rpm could this be a bad oil pump? any advice is great thanks.
kwkracing 01-02-2010 12:38 PM
Are you sure the convertor was all the way in the tranny when you installed last nite? Did it function properly then? Is it stock?
TheYellaBrick 01-02-2010 02:27 PM
Dump in enough Trany Fluid ?
SkylerFaoro 01-03-2010 04:06 PM
Yes converter is all the way in and yes it is bolted. yes it worked perfict than didnt work. yes stock converter. and yes plenty of fluid
