-   -   Chain Drives (https://www.racingjunk.com/forums/showthread.php?t=26875)
showbusiness 01-01-2010 02:21 PM
Chain Drives
Any mudracers,trying to go to a chain drive setup,is this possible to come out of a shortened glide with a sprocket,drop straight down to a sprocket which in turn is going to front and rear diffs. which are both centred instead of offset. Thanks ,any pics or ideas greatly appreciated. SHOWTME RACING/Norm
showbusiness 01-03-2010 03:24 PM
chain drives
No mudracers out here.
DRTRCR22 01-03-2010 07:05 PM
Well... I sling a lot of mud at the begining of the night, but I don't think that counts... :) :)
http://i850.photobucket.com/albums/a...R22/Track2.jpg
showbusiness 01-05-2010 02:07 AM
Chain Drives
Thanks for reply.Norm
TheRabbit 06-25-2010 04:28 AM
Don't know how I missed this post. You can do it that way or buy the shaft from Power Pro which uses two shafts. One shaft goes between the drive shaft and trans and other shaft runs the front shaft. Will cost you about 950 to $1,000 for everything including chain and sprokets.
No matter which way you go make sure to put a plate on the rear tail shaft to keep from pulling the trans to the right and ruining the rear bushing or bearing. I don't have any pics of mine but can get some if you'd like.
showbusiness 06-27-2010 04:12 AM
Chain drive
I never realy looked at the set ups i guess, i see most are from trany to rear diff. with a sproket on driveshaft and chain going over to connect with front shaft which is probably the best.The biggest prob. would be supporting my output shaft where i was thinking of putting the sproket, any pics out there of set ups. Thanks :? :?
jbworkman9 06-30-2010 09:50 AM
i run front and rear off bottom gear. its one of gary bakers blower chain drive sets ups i had to face the bottom gear and run the industrial grade diamond double 60 chain its a little wider than the standard D60 but works great. the standard chain would break every 8 or so passes .
showbusiness 06-30-2010 03:32 PM
Thanks ,i just didnt know if it would stand.
TheRabbit 06-30-2010 03:37 PM
Hey Jill. You get Taz fixed? Hope to see ya'll again soon!!
jbworkman9 06-30-2010 04:34 PM
no not yet sent the 7531 and the 7530 back to msd to get them fixed said it would take 3 weeks. so guess ill be down for a little lol. hope to make next race at hubcity hopefully see ya there
