fuel injection question
i have a 496 around 10:25.1 compression steel heads ported with 2.19 1.88 valves full roller motor comp cam 300/306 hyd roller. i would like to find a cheap fuel injection setup. is it possable?
What's 'cheap' ? Inexpensive but junk, or reasonably priced used high quality, or expensive new high quality ?
How much are you expecting to spend ? Mechanical or electronic? |
i dont know if it is in the budget or not. if i know what i can use maybe i can peice it together
Used units go for $1200.00 to $2000.00 on ebay and here on RJ. I sold a 2 7/16" stacks unit about 6 mos. ago for $850.00 setup for gas. It all depends on if you want stacks, a toilet bowl or a hat. I've got 2 Crower stacks units but they are too big for 496" motor.
Zip. |
i need a setup for pump gas
There's a toilet bowl with everything minus a couple brackets for $850.00 here on RJ in the ad section.
Zip. |
| All times are GMT -8. The time now is 06:59 AM. |
