Bead Lock Wheels
I see lots of cars now running with bead locks and I wonder if they really need them. Fuel cars, no doubt, but your everyday bracket car, well I have my doubts. My question is do I need to put bead locks on my car, a 3000lb car with somewhere around 1000hp?
I run 6.8 sec quarters at 198mph and use rim screws. Bead locks look cool, cost a hellova lot and are really only needed over 200 mph.
I can tell you why most put them on bracket cars ... they are more consistent, its been proven several times.
So would you use double or single bead locks?
Is it the extra mass of the lock rings being so far from the center point of the axle? |
Less sidewall movement not tire movement on the rim ....
But of course this is to a point if you dont have the power to lug the extra weight your just wasting your time, but by all means if you got the HP the beadlock is the ticket .. |
I thought about the bead locks for my wheels, but decided since the locks add about 8 lbs per wheel there was no performance gain by using them. It's been said every 10 lb of rotational weight is equal to 100lbs of sprung weight. So thats like adding 160 lb. to your car. Locks do look cool though! :wink:
| All times are GMT -8. The time now is 01:04 AM. |
