-   -   FLAT TAPPET CAM SPECIALIST (https://www.racingjunk.com/forums/showthread.php?t=26789)
et7333 12-23-2009 12:09 PM
This is the current combo I am using in my drag car:
383 sbc,13-1,dart iron eagle 215 platinums,super victory,comp flat tappet,.558 550,260,[email protected] 108,ALKY 750 carb,3100 lb camaro
We are building a sbc Dart SHP 4.030 13.5-1 and I have a set of old iron eagles,not platinums that I might have some port work done on.The person who is porting the heads told us he will port the heads to 280 cfm @ .650,What FLAT TAPPET Cam Specs,NOT ROLLER,would you use? Remember this engine runs on Methonal.
Thanks
zipper06 12-23-2009 05:43 PM
Loves Alcohol, worked good with Brodix T1 heads which flows between 270 and 275 out of the box.
http://img.photobucket.com/albums/v5...tcambullit.jpg
