question about nos solenoids
i have a cheater plate but i need to get new noids
do i have to run the cheater noids or can u use say powershot or super powershot noids i know the orifice is defferent and ive heard it will change the size of the shot is this true....im new to the hole nitrous thing and any advice would be appreciated |
Plate
You can run ANY Noid you want!The Noid has a Limit of what it will Flow,as the Plate?
Later G 8) |
I had a 400 powershot plate system on my Camaro. It came with Cheater solenoids for the fuel.
NOS
You can run any solinoid you want but the bigger the orfice on the solinoid the more it will change your tune up so be careful.
I had a Top Sportsman Car that I used to brag I only shot with 200HP jets, however i had the big NOS brand bottom exit Nitrous solinoid on it and it does make a big difference. |
nitrous solenoids
How often do you need to rebuild them?
Re: question about nos solenoids
| All times are GMT -8. The time now is 12:32 PM. |
